update time!
since the last time I posted I've got the whirlwind fully decalled, however the colour of the letters, when seen in real life is quite a bit more green than the paint I used on the spinners and fuselage band (the band is supplied as a decal, but I find it easier to mask and paint them)
what I will do is to lightly paint over the letters with some of the sky colour, here I have painted over the "F" and whilst its hard to see in this photo, it does tone the lettering in with the rest of the colour scheme.
and then onto the landing gear, up until now I have had the gear doors in place for painting by simply putting a blob of blutac in the well, and pushing the door onto it, to make painting the undersides that much easier.
now these doors, if just glued to the edge of the opening will be really flimsy, so what I have done is to drill a small hole in the edge of the door, and this is where the out of scale thickness of the piece works in my favour-
also you can see where I have thinned down the other three sides
then I glue a piece of wire in there
and then just glue it through a hole I made in the nacelle edge. when set its quite a sturdy joint and allows me to easily make adjustments to the door's fit.
the finished product! now i just need to get the other side and the tail wheel done, then i can think about a matt coat then aerials.
