entire network: 6,965 Posts
KitMaker Network: 609 Posts
Posted: Sunday, May 20, 2012 - 04:08 PM UTC
When once you have tasted flight you will walk the Earth with your eyes turned skyward.
For there you have been, and there you will always long to return.
-Leonardo Da Vinci
entire network: 7,078 Posts
KitMaker Network: 42 Posts
Posted: Sunday, May 20, 2012 - 10:08 PM UTC
Paul, both the 110 and the Hurri are looking good.
Andy, Great work on the 109. looking really cool, good luck with the Spit.
Jessica, Both the Albatros & the Spad coming on really well.
Only a small amount of progress on the MTB, busy weekend with family, and the Hendon Model show.
Boat hool rack fitted anfs the three boat hooks cut to length.
More soon
Si
Posted: Monday, May 21, 2012 - 08:06 PM UTC
Foredeck fittings almost finished,
From the photographs of the boats I cannot see any visible lashings for the Carley Float, so I havent included any, One strange omission from the etch and the instructions is fixings for the anchor, these are clearly visible on pics, so the final job there will be a bit of work with some strip and rod.
Si
Posted: Sunday, June 03, 2012 - 06:14 AM UTC
A bit more progress, I have started work on the rudder assembly. The boat has three rudders, one astern of each prop, above each rudder is a cavitation plate, each cavitation plate is made from three etched parts, the plate itself and 2 brackets, the rudders are white metal, and brass rod is provided for the shafts. The shafts are not yet cut to length, I will go that after I have sprayed them.
Si
entire network: 1,381 Posts
KitMaker Network: 176 Posts
Posted: Monday, June 04, 2012 - 06:15 AM UTC
hi all, i'm going to call this one done.
hurricane v bf110
the 110 kit is a bit of a nightmare to be honest but the sweet hurricane is a lovely little kit.
its been good fun doing this and watching everyone else as well.
all the best
paul
Posted: Tuesday, June 05, 2012 - 05:22 AM UTC
Nice job Paul, and well done fo finishing.
A bit more progress, the rudders and cavitation plates have been fitted to the stern of the mtb, just needs mast, rigging and a couple of finishing touches, meantime I have started the s-boat, below pick gives an idea of the size difference of the two vessels.
Si
Posted: Tuesday, June 05, 2012 - 01:00 PM UTC
The Albatros now has a complete fuselage and the basic colours are on. I'm hoping that the red will be just transparent enough for them to show through slightly.
-Leonardo Da Vinci
Croatia Hrvatska
entire network: 977 Posts
KitMaker Network: 88 Posts
Posted: Friday, June 08, 2012 - 10:02 AM UTC
Hi Michael,i was sick and away for some time,is the deal still on,my centurion vs. your t-55?
Kind regards,Sven
http://svenharjacekmodels.blogspot.com/
Posted: Sunday, June 10, 2012 - 09:42 PM UTC
The Albatros is looking good Jessie,
A bit of fine weather on Sunday allowed me to get the airbrush out, so the deck on the e boat has been masked and the hull sprayed.
Si
MichaelSatin
Campaigns AdministratorColorado, United States
entire network: 3,909 Posts
KitMaker Network: 134 Posts
Posted: Monday, June 11, 2012 - 04:47 AM UTC
Kind regards,Sven
Sven: I'm still on board, but I thought it was the other way 'round, I was doing the Centurion and you're doing the T-55. Did I get mixed up?
Great work everyone!
Michael
On the bench:
Sorta depends on your definition of "on the bench"...
Croatia Hrvatska
Posted: Monday, June 11, 2012 - 06:39 AM UTC
Sure,even better,i have a t-55 in my stash.
Ill search for some ref. pictures and start.
Posted: Monday, June 11, 2012 - 05:28 PM UTC
The Albatros is looking like an airplane now : )
Upper wing ballanced on the cabane struts.
I need to clean up the blue overspray from the underside and remove the ailerons to get the cutouts done properly.
The fuselage is nearly ready to become red.
I need to figure out how to mask that engine without spoiling the red. The tolerances over the intake manifold are very tight, so tight that I don't know how to get any masking material in there. We'll have to see how it works out.
-Leonardo Da Vinci
Posted: Wednesday, June 13, 2012 - 08:04 PM UTC
Looking good Jessica.
A bit more progress on both boats, on the mtb, the last details have been aded to the wheelhouse, handrails & lifebouys, and the mast fitted. The s boat has had the hull sprayed, light grey above the waterline and black below, and I wooden planking on the decks painted. a bit more tidying up & detail painting to go before construction work starts in ernest..
Posted: Sunday, June 17, 2012 - 09:19 PM UTC
More progress on the S-Boat.
The rear ends of the torpedo tubes have been added and detail painting started. The foredeck, along with it's gun tub have been fitted.
Work on the upper bridge has commenced, still needs decals & and some detail painting.
this was then test fitted with the armoured wheelhouse shell.
Si
Posted: Monday, June 18, 2012 - 05:35 AM UTC
Red airplane is red.
Rolling up the etched cooling jackets and gluing on the tiny parts was extremely nerve-wracking.
-Leonardo Da Vinci
Wisconsin, United States
entire network: 1,917 Posts
KitMaker Network: 133 Posts
Posted: Monday, June 18, 2012 - 07:13 AM UTC
Simon, that planking is awesome!
Jessica, it's good to see that the red airplane is red, but the engine is not!
...is Jesper still watching out for that P-51? When you least expect it, expect it! (ha ha, giving an evil mustache twirl.)
-Sean H.
Current: model railroad layout
Stalled a while ago:
. 1950's Chrome, WW II Twins
Last completed: Police Car
Posted: Monday, June 18, 2012 - 02:12 PM UTC
Et maintenant, après beaucoup de travail dans l'Usine SPAD*...
Lots of fit problems with those upper deck pieces. It's going to take quite a bit of work to sort them out..
*And now, after lots of work in the SPAD Factory...
-Leonardo Da Vinci
Posted: Monday, June 18, 2012 - 07:07 PM UTC
Albatros looking great Jessica, good luck with cockpit coaming on the spad.
Thanks Sean, a simple bit of drybushing with citadel bleached bone, gives a nice uneaven worn look.
Si
Posted: Wednesday, June 27, 2012 - 08:35 PM UTC
More progress on the s boat, the bridge has been painted and fitted, would note there is an error in decal placement the instructions, it shows decal 5 in the centre position on the bridge consol, rather than 3, which appears to be the correct one.
Si
Posted: Thursday, June 28, 2012 - 03:46 PM UTC
Der rote flieger mit dem Flügeln!
Still lots left to do, but it's looking more and more like an airplane.
-Leonardo Da Vinci
Posted: Monday, July 02, 2012 - 01:39 AM UTC
A bit more general progress on the E Boat, addition of the myriad of parts around the foredeck & maindeck.
more soon, Si
MichaelSatin
Posted: Monday, July 02, 2012 - 01:47 AM UTC
Jessica and Si,
Thank you two for holding up the banner for this campaign! I've actually got some paint on my 1/32 Albatros D.V and hope to actually take some pictures soon, but you're doing great work!
Michael
On the bench:
Posted: Wednesday, July 04, 2012 - 10:38 PM UTC
Welcome Micheal, looking forward to seeing the pics.
Si
entire network: 470 Posts
KitMaker Network: 36 Posts
Posted: Saturday, July 07, 2012 - 03:00 PM UTC
My original plan was to go with a Liberator to go with my completed Oscar, but with starting the miniature figure business, 2 kids on holiday...blah I hate real life getting in the way of modelling. So I had to go with something cheaper. I found this new tooled Airfix Hawk to go with my Oscar. I have always loved the Hawk family. Kittyhawks, Hawks, Warhawks. They are ugly in a beautiful kind of way. This puppy was 7.99 Canadian. Less than 10.00 for a kit that is new tooled and doesn't suck. I love Airfix.
The fuse goes together without the cockpit. I was shocked! I have seen this idea before but never on a 1/72 kit and it worked out pretty well. The fuse fit is good to excellent and some sanding with no filler needed smoothed it out.
The cockpit attacked to the lower wing is fixed in place. Overall it fitted pretty well, but I had one worry about how the wings would fit.
Oh snap. There goes the wings. They fit everywhere except at the fuselage. So there will be sanding and filling needed there. Overall...not bad and for 7.99 damn excellent, but its a pity the wings were not a tighter fit.
Try to get back to it tomorrow. Propeller is meant to go on but I want to paint them off the plane. tail is next up.
Posted: Sunday, July 08, 2012 - 07:19 PM UTC
Looking good Aaron,
More booring bits on the fore & main decks om the s-boat.
decided to get on with some interesting bits as well... the torpedoes.
more soon
Si
