I realised that my first tarp was hanging wrong and I came across a pic in my reference of the frame to show where I had gone wrong !!!! I had placed the first and last bow inboard a fraction of the uprights instead of directly above them !!!!!!
Used this tarp as a practice for painting so not totally wasted !!!!!!!!!! You can see the ends of the tarp slope inwards instead of sitting upright !!!!!!!
The tarp side panels have the edges folded for reinforcement so they could be holed for the ropes !!!!!
The rear panel has the edges folded and in the fold I put thin florist wire so that I could role the sheet for posing in the open position !!!!
Having sorted out the f**k up on the bows, I set about making version two of the tarp and went about it slightly different !!!!!! I used croc clips to tension the cling film and sprung tweezers to weight the end vallances !!!!!!!!!
Instead of trying to size the tarp over end to end as well as side to side and risk the tissue tearing, I place a sheet on the top surface from bow to bow without any overhangs !!!!!!! I then made two side strips identical of double thickness tissue with the florist wire in the fold to the depth of the overhang and pasted these on the edge of the first sheet !!!!! Used the hair dryer to speed the drying out !!!!!
I drew the end panels roughly on the tissue and added a fold and florist wire on the bottom edges again !!!!!!!!! Pasted these gently onto the ends and blow dried them before trimming and pasting down the overlaps !!!!!!!!!!!!!
The end and side vallances are much neater and sit straigther and smoother !!!!! Although the whole tarp is very tight and will not be able to come off the frame !!!!!!!!!!!! No biggy there though as I can make another frame up very easily to pose without a tarp !!!!!
While working i rolled the chair over one of the cargo bed corner posts and had to fix it !!!!!!
Hope I don't break any more vital parts !!!!!!!!! The ropes on the side panels were threaded through holes pierced in the tissue with superglue on the end of a cocktail stick pressed in the holemaking a convincing rienforcement ring !!!!!!!!! I might tie down one side and have the other side opened up or the side panels off and folded !!!!!!!!! Still to decide !!!!!
Some pastels and weatheing powders will take some of the sheen off the paint but I like this tarp better now !!!!!!!
Will sleep well tonight !!!!!!!!!!!!
