Hi Rick
Thanks for looking in from time to time ,,,,,,,,,,,, always appreciated !!!!!!!!!!!!!!!
A big thanks also goes to Tony of HMVF ( AKA NOS and the person who tips his cargo bed on its side just for my photos) as all this detail could not have been as easy to do without his fantastic assistance, photos and measurements !!!!!!!
Thanks Tony
Been working on the cargo bed using balsa sheet cut into strips and then reglued out of sequence to vary the grain of the wood with the runner spacers embossed and marked with permanent marker only for the moment until I can find thin strip to add in its place
The headboard fixed to the sub frame runners
And the start of the cross bearers
And with timbers dry fitted as still a bit of cross members to be done and some cuts outs for the iso lugs and rear most pairs of tie downs
Two additional tie downs have been drilled in front of the head board since
I might need to check my sizes around the rear axle mudguards as something does not line up true with the cross bearer. Worst caseI think might need to transplant a little plastic back where cut off !!!!!! No real biggy though !!!!!!!!
Hope you like
Nige
