Also means a bit of patching of the holes left at the corners. Well my Landy needed lots of patching up to keeping it running, so I will put it down to damage by cargo or summit.
Placed the Monogram engine block and gearbox in the lightweight to see how it would look. Intension being to use this as a guide to scratch a basic engine to go under the hood. After all, will need the engine for the 88.
Surprised myself how easy it fitted in, though using the 88 chassis as my guide meant I had to be close, even with the slight bodywork differences.
Made a start using large section rectangular hollow tube glued between sheet end pieces. The top is set in the narrow plane vertically, and the bottom with the narrow plane horizontally.
The space in between filled with thin sheet to place all the other componants on to build up the general shape.
The sump is another section of the hollow tube, this time laminated with thick p/card to get the required width, then sanded to profile.
More to follow when time allows
Nige
