progress pics (F-4F) pinoy version
riversphynxz
Metro Manila, Philippines
entire network: 262 Posts
Posted: Thursday, June 03, 2004 - 01:46 AM UTC
klinger
Just wanna ask more about the instruments. As I understand it, you paint the gray first. After that, how did you paint the black on the individual instrument panel bases (i.e., some instruments are on a square sort of frame while some are on circular frames)? Were this masked then sprayed on?
Finally, how did you do the yellow/black bars panels?
Just wondering
LaTtex,
i only spared the panel once (gray paint). the dials are achived by dry brushing(black) then the white paint then dry brushing again (black).
the yellow and black bars are done like this, paint the panel white first then yellow. wait for the paint to dry first before you put the second color and wait again for the yellow to dry again. most white and yellow colors (gloss) are thick in nature,so start with thin coats first. you can apply a second coat if the color is too faint but make sure the first coating is dry or you will peel it if you will apply the second coating to soon. for the black lines you can use tech pen 0.1-0.3. or if you are adventurous enough, use your 001 paint brush. start with a thinned black paint and gradualy building it up. always thinned your paints before applying them in your model. my techniq is brush to thinner, brush to paint (can), brush to palatte, brush to thinner, brush to palatte, then brush to model. practice makes perfect modelz.
riversphynxz
Posted: Thursday, June 03, 2004 - 12:30 PM UTC
as promised guys, here some progrss picz.
the faded effect on the paint vanished after applying future/klear but will soon come back after few coats of flat. seems like its a mig killer huh...
riversphynxz
Posted: Thursday, June 03, 2004 - 12:35 PM UTC
probly tomorow, clear flat will finish the job. i'l keep the picture coming....
buck
entire network: 437 Posts
Posted: Thursday, June 03, 2004 - 09:44 PM UTC
Yes, please! The Phantom is coming along very very well. Cant wait to see the finished bird. Bilis mo gumawa, Klinger. Ako Im currently in a modeling slump. The Tamiya 1/16 figure is giving me a difficult time kasi eh.
riversphynxz
Posted: Friday, June 04, 2004 - 01:12 AM UTC
i also noticed that buck that i'm on a fast pace. just finished flat coating and shading it.if i'm in a right mood,2-3 hours max per session preo kung wala tlagang magawa, maghapon. mya ko na upload yun pixz, kain muna ako.
riversphynxz
Posted: Friday, June 04, 2004 - 02:01 AM UTC
here is my almost finish phantom. 99%painted and 80% weathered, 90% finished.
hay, kapagod. seats, undercarriage and weapons naman.
shonen_red
entire network: 5,762 Posts
KitMaker Network: 2,610 Posts
Posted: Friday, June 04, 2004 - 02:12 AM UTC
Huwow!!!! Paturo naman sa sexy shading na yan! Is that postshading?
blitz
entire network: 502 Posts
KitMaker Network: 432 Posts
Posted: Friday, June 04, 2004 - 02:56 AM UTC
Klinger... Ang bilis mo mag work ha!!.and ganda nang weathering and shading. Almost there!!
riversphynxz
Posted: Friday, June 04, 2004 - 03:06 AM UTC
the shading can be done by mixing flat coat with a tiniwiny drop of black paint then airbrushed. trial and error lang ako dati then i like the result. i also did pre shading before but i think i'm a li'l bit heavy when i paint so nawawala un mga shades after the painting. those shades are nice specially on corners, it really makes a shadow.
buck
Posted: Saturday, June 05, 2004 - 01:39 AM UTC
Drip... drip... drip ...
The sound of saliva drooling.
Galing! Very very nicely done, Mr. Klinger! Ive done the same technique of post shading --- mixing black with clear. But the one you did on this Phantom is very impressive indeed!
riversphynxz
Posted: Saturday, June 05, 2004 - 01:50 AM UTC
akala ko kung anung "tulo" yun... :-) :-) :-)
still a long way to go buck, i still need to sort out the seats, pylons, bombs and undercarriages. i also need to draw some panel lines as well ( my rotring techniq ). i like shading because it give you more depth like on wing/fuselagecorners. i'l kepp you poste but pahinga muna, i will go to UK motor show first. see yah
BlackThor_06
entire network: 200 Posts
Posted: Saturday, June 05, 2004 - 10:56 AM UTC
A very beautiful Double Ugly there.
What kit is this? Revell AG?
A comment though: The F version of the F-4, if I'm not mistaken, is exclusively used by the Luftwaffe. The USAF used the F-4E variant.
The E and F look very similar anyway.
Again, a magnificent build. The pit details alone totally blow me away.
BT6
jepot
Drenthe, Netherlands
entire network: 37 Posts
Posted: Saturday, June 05, 2004 - 11:26 AM UTC
Very exquisite work Klinger! You mentioned using paediatric needles; i usually use spinal needles gauge 25 for representing .50 cal gun barrels and gauge 23 spinal needles for 20mm barrels; do you use such too? The stylette can also be useful as a pitot tube... also worn out pulse oximeter probes have wires that are very fine- kinda useful too for wirings of wheel wells or whatever; do you use that too? just asking...
riversphynxz
Posted: Monday, June 07, 2004 - 10:35 AM UTC
BT6
i agree with you mate, the kit itself is a german plane but i decided to change the decal. if you find a revell kit, you will see the german plane, i just used the kit to represent an F-4 that was base in the philippines. E and F are very similar indeed.
riversphynxz
Posted: Monday, June 07, 2004 - 10:37 AM UTC
most of my details are from medical things like needles, scalpels, siphon, tubes etc. i found our stock room as second hobby shop. :-) :-) :-)
jepot
Posted: Monday, June 07, 2004 - 09:42 PM UTC
Correct Klinger; the hospital is a veritable supply depot of items we can use for scratchbuilding; i owe Hermie ( Guarnere) my curiosity for scavenging hospital stuff for when we first met at PGH back in 1992 ( he was a graduating anesthesia resident and i was incoming), his room which i consequently inherited was full of needles, more so spinal needles. The scrathbuilt AIFV i made from an KIFV kit ( seen at www.geocities.com/afponlinemuseum/Cover.html) has an epidural needle for the 25mm KBA gun and spinal needle gauge 23 for the external fluting of the gun; today, i regularly supply Ramrod the expended pulse oximeter wire for him, and SNGs for whoever cares. Even the wrappers of surgical blades i save as lead foil for gun slings, uniform edges, etc...
What specific medical line items did you use for this kit of yours? im curious...thanks!
riversphynxz
Posted: Tuesday, June 08, 2004 - 08:43 AM UTC
mostly needles for the cannon, pitot tube and struts. i also used the catheter size guide for the diameter of the body of the cannon and braces/support.
jepot
Posted: Wednesday, June 09, 2004 - 12:32 AM UTC
OK Klinger, keep up the great work; though i dont post that much sa internal email natin sa BAC, i monitor things quietly....Cheers!
riversphynxz
Posted: Wednesday, June 09, 2004 - 12:27 PM UTC
so you are a silent sniper type huh. no progress on my model, still busy editing motor show pictures.
riversphynxz
Posted: Tuesday, August 10, 2004 - 05:31 AM UTC
some progress on my F-4
cardinal
Visayas, Philippines
entire network: 1,008 Posts
KitMaker Network: 492 Posts
Posted: Tuesday, August 10, 2004 - 05:56 AM UTC
Whoa! Awesome build there Klinger. I particularly like how the panel lines are highlighted by your wash.
buck
Posted: Thursday, August 12, 2004 - 10:20 PM UTC
Lookin real good, Klinger! Cant wait to see it finished.
riversphynxz
Posted: Tuesday, August 31, 2004 - 04:52 AM UTC
At last, the finish product...
hope you like it.
shonen_red
Posted: Tuesday, August 31, 2004 - 12:34 PM UTC
Wee! Sweet! Alakalin mo 1/32!
BlackThor_06
Posted: Tuesday, August 31, 2004 - 08:59 PM UTC
Ang gwapo niya!
Please show several photos of your kit from different angles!
LONG LIVE THE RHINO!!!
BT6
