User Support
Having a problem with the site? Post it here.
having a problem uploading photos ..
staff_Jim
Staff MemberPublisher
KITMAKER NETWORK
New Hampshire, United States
entire network: 12,571 Posts
KitMaker Network: 4,397 Posts
Posted: Wednesday, October 08, 2008 - 10:37 AM UTC
Sorry I was just alerted to this topic. I made a permissions change to the Member's Gallery parent menu and obviously that has had some negative side-effect for accessing your own albums (unless you are an admin). This may take some time to correct as I will have to do a bit of experimentation to see if I can even reverse the settings on 4000+ user directories. In the meantime I suggest if you want to upload new pictures you create a 'new' album and see if that doesn't work. I would guess this is only affecting the albums that were already created.
Thanks,
alpha_tango
Germany
entire network: 5,609 Posts
KitMaker Network: 67 Posts
Posted: Wednesday, October 08, 2008 - 10:53 AM UTC
Hello Jim
I know you are probably in the middle of testing. I now see the Member gallery again and i could upload to it. I created a new album but I could not find it in the list (maybe I just missed it, I will have a closer look again)
Thanks a lot
Steffen
P.S. I could move the "Error Pic" from Avatar to my gallery (still no joy on sub galleries)
alpha_tango
Germany
Posted: Wednesday, October 08, 2008 - 11:10 AM UTC
Cool everything back to normal now!
A BIIIIIG THANK YOU, Jim!!!
all the best
Steffen
staff_Jim
KITMAKER NETWORK
Posted: Wednesday, October 08, 2008 - 11:17 AM UTC
Your welcome and glad to hear it's fixed. It luckily wasn't too big a code issue.
AIRGUNNER
entire network: 246 Posts
Posted: Wednesday, October 08, 2008 - 11:18 AM UTC
Hi all,
Not sure if my problem is linked, but I only have 10mb space in my Gallery, only enough to upload about 10 photos! I notice in the first screendump Steffen did the user amount was unlimited. Is this a staff only thing<
AIRGUNNER
Disk space allowed on your account: 10,240kb (10,485,760 bytes)
Disk space used on your account: 10,478,630kb (10478630 bytes)
Disk space remaining for your account: 7kb (7130 bytes)
alpha_tango
Germany
Posted: Wednesday, October 08, 2008 - 11:31 AM UTC
Hi Steve
well, you should reduce the size of your pix .. 1MB per pic is very (very!!!) large for internet use!!!
100-200 kb should be more than sufficient ... reduce the resolution to 72-150dpi. More that 800 px width is not supported here, so you can reduce the pix to this size (you often get below 100 kb this way)
all the best
Steffen
P.S. I just looked at your gallery and there are already 28 pix ... checked one regarding the size; it had 59kb .. so you have a lot of space left
