1⁄35Scale Comparison - 1/48th vs. 1/35th
Size/Scale Accuracy
I wanted to measure and compare the kits side by side and see how they measure up. I found this great website while doing research on this project. It gave me some very good measurements. I measured each completed kit at the same locations, making sure I started and stopped at the same places.The following table shows the actual life size measurement along side the converted size with the kits actual measurements. All measurements are rounded to the nearest whole number.
| Measurement | 1:1 | Actual 1/48 | Kit 1/48 | Actual 1/35 | Kit 1/35 |
| Wheel Base | 2400 mm | 50 mm | 49 mm | 69 mm | 70 mm |
| Length | 3700 mm | 78 mm | 75 mm | 106 mm | 104 mm |
| Width | 1600 mm | 33 mm | 33 mm | 46 mm | 45 mm |
| Height (no top) | 1111 mm | 23 mm | 23 mm | 32 mm | 31 mm |
Overall it’s not bad, there are some differences. The differences appear to be consistent between the two kits. The measurements speak for themselves. There aren’t any gross size differences.
Copyright ©2021 by Scott Lodder. Images and/or videos also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of KitMaker Network, KitMaker Network, or Silver Star Enterrpises. All rights reserved. Originally published on: 2006-04-29 00:00:00. Unique Reads: 16919
