1⁄35Sparrow
drawings
With a major component sized and ready I was now able to work on planning the ship section. Drawing out a project on paper helps me develop ideas of how I will build the end product. I try to draw the items in proportion to each other to give me a better idea of how things will fit together. This is the time to really experiment with position and spacing. It’s easier to erase a drawing than to unglue a poorly planned piece.After the test sketches are worked out, my next phase is to draw at least an elevation (side) view and a top view drawing to scale. Sometime I’ll do a perspective drawing to help establish a point view for viewers.
TIP:Calculating scale drawing does not have to be vertical (1:1 to small scale). We all know how to convert 1:1 measurements to our particular need. Sometime you don’t know the 1:1 size. One way to figure this out is to use secondary measurements. Compare a known 1:1 item that you do have measurements for. Then calculate the needed 1:1 item then downscale. Another way is to find another small scale item the same as what you’re looking for then scale it horizontally from the small scale to your desired scale. Example: if you have a 1/72 scale version, just rescale it directly to 54mm or vice versa. My example in this project was that I found a 1/10 scale canon kit and used it to calculate a 54mm canon.
Test build
If I scratch build a large item, such as the ship, I try to make a mock-up first. I typically use some type of paper, a heavy card stock or an old file folder. The mock-up serves as a tool to get a rough idea of angles, sizes, composition and fit. It is so much easier to adjust and fix things at this point. You don’t use expensive wood and mold materials aren’t wasted plus small details are accounted for and adjusted for early. It ultimately results in a better project and most of all less frustration.
In my project this mock-up really showed me that a squared off base was not going to work. The positioning of the figures with respect to the canon needed an oblong shape. Not to mention my ever preached rule of “nothing parallel”. This holds true even with a small project like this. The square base was very boring vs. the asymmetrical shape I settled on. With the paper mock-up I was able to work out the shape and positioning of the steps with respect to the canon and poop deck.
The paper versions also double as templates for the final product.
note:When working with paper mock-ups be very aware of thickness. The paper is not as thick as any wood product you will ultimately use. So, in your measuring, take this into account. Wall thickness is the primary area of concern with this.
OCT 07, 2006 - 08:21 PM
Arrrrr!!! Nice work matey!
OCT 07, 2006 - 11:55 PM
Thanks for the complements
PS - the links are on page 14
OCT 08, 2006 - 12:46 AM
Hi scott,
OCT 08, 2006 - 02:13 AM
Joe
OCT 08, 2006 - 09:28 AM
OCT 08, 2006 - 04:12 PM
Well done Scott
Claude
OCT 08, 2006 - 06:03 PM
