1⁄35Sparrow
Tip: Gluing
Never put glue directly from the tube/bottle directly on your part. I put whatever glue I’m using on a scrap piece of plastic card and dip the wire into the glue so there isn’t an excessive amount on the wire. Or I will use a sharpened toothpick to apply the glue from the plastic card to the wire or part.
Once the glue is set I fill the gap with putty. Once the putty is dry I sand it down. The beauty of this whole procedure is the ability to tweak the position of hands and feet. You are better able to make figures ‘hold’ implements and equipment. You can also create more realistic gestures. You can do this with any type of figure; I have done this extensively with resin figures and a number of type with injected plastic figures.
This is the basic technique for replacing hands with After Market sets.
The feet went together using the same technique. I added a second extra long wire to the base of the foot. The long wire would serve two purposes. It gives me something to hold and put in a vice while I am working on the figure and it will act as a final positioning post. When I drilled a hole in the foot I had to select a location that would give me as long a hole as possible to give me as much support as possible for the final pose. The length of the foot was the decision and with the hole drilled and the wire glued in I was able to bend the wire to a more realistic position. The point here is that the wire does not have to go ‘straight’ in and stay that way.
The rest of the assembly was straight forward. I used some two part epoxy and glued all the upper body parts together and the lower body parts together as separate subassemblies. I always save the waist for last. It’s a critical connection that can hinge on arm and leg positioning. There was some sanding on the torso and waist to get a nice clean fit, once that was done I glued them together. I always save the accessories for last. This is because they too may be affected by where legs and arms end up.
Tip: Hollow Out things
With these figures there were two specific pieces that needed added attention. The gun holster and the scarab needed an extra touch. They were both molded with a solid end and no representation of depth. This is an easy effective way of adding great detail to your projects. I hollow these out to give them real depth. I first use an appropriately sized pin vice and drill some pilot holes to get out the majority of the material. Then I use a combination of a sharp #11 blade and a dental tool to pick out the remaining material. This can be done with holsters, sleeves, helmets, helmet rims, gun barrels, etc.
OCT 07, 2006 - 08:21 PM
Arrrrr!!! Nice work matey!
OCT 07, 2006 - 11:55 PM
Thanks for the complements
PS - the links are on page 14
OCT 08, 2006 - 12:46 AM
Hi scott,
OCT 08, 2006 - 02:13 AM
Joe
OCT 08, 2006 - 09:28 AM
OCT 08, 2006 - 04:12 PM
Well done Scott
Claude
OCT 08, 2006 - 06:03 PM
