1⁄35Sparrow
Real Build
My first matter of work with the actual build was planning again. My plan was to provide a good solid stage for this scene which required thick material. I knew I need thick wood material for the floor and outside hull of the ship to offer the viewer a realistic sense of mass and strength to hold up canon and endure long voyages. In addition I knew the type of wood used would make a difference. For modeling in this scale there are two basic types of wood – balsa and bass. Balsa is very common and popular. It is easy to get and inexpensive. The downside to it is the grain is very open and ‘loose’. It is very soft and porous. Bass wood is not quite as common and is more expensive. Bass wood has a tighter stronger grain. My plan was to use household wood stain as a finish for most of the project. This too played into my decision on which wood to use. The more open grain of balsa soaks up stain in large quantities but disburses it deep within itself. Your stain work time is short and the result is a washed out look. Bass wood soaks less stain and has longer working time. This allows you to rub off excess or rub in more to get a richer color. The color that remains is a deeper richer color. It was all of this that made me choose bass wood.all hands on deck The first matter of construction was the deck. Easy enough lay the pattern out on a piece of bass wood cut out and sand a bit to shape. Selection of thickness was the largest factor in my decision on which stock to use. I paid special attention to the thickness and scale of the poop deck vs. main deck. The trim rail vs. the main deck and even down to the rigging details. I wanted a fairly authentic look and feel to the piece and my research showed that all of these parts were made from different wood stock.
Note: take advantage of the tools you have. I have a multi-function tool that acts as a table saw. I used it to cut out the larger sections of my pieces. It is nice to use some electric tools for speed reasons. If you don’t need fine tuned close control the electric versions of tools are great. They give you fast function and don’t sacrifice control.
Once selected and cut I used a dental tool to scribe in plank lines and nail holes. It is always a good idea to scribe lines using a metal ruler as a guide. The ruler will keep the tool from drifting away from the pre-drawn line.
I created every piece before I assembled anything. This ensured that I did not leave anything out and if I did I would not have any problems creating it. Nothing is glued at this point so nothing is committed.
Construction was done with some white glue. I was very careful not to get any excess white glue on the pieces. White glue would have inhibited the stains ability to soak in and the finish would have been ruined where excess glue seeped out.
OCT 07, 2006 - 08:21 PM
Arrrrr!!! Nice work matey!
OCT 07, 2006 - 11:55 PM
Thanks for the complements
PS - the links are on page 14
OCT 08, 2006 - 12:46 AM
Hi scott,
OCT 08, 2006 - 02:13 AM
Joe
OCT 08, 2006 - 09:28 AM
OCT 08, 2006 - 04:12 PM
Well done Scott
Claude
OCT 08, 2006 - 06:03 PM
