How I Build Dioramas
dolly15
entire network: 8,227 Posts
KitMaker Network: 1,502 Posts
Posted: Tuesday, November 14, 2006 - 07:35 PM UTC
dolly15
Posted: Tuesday, November 14, 2006 - 07:54 PM UTC
This is the floor after the initial pinhole punching and pencil coloring routine.I have yet to brush or spray on the thin wash of raw umber.Some of the larger openings in the boards I sometimes take a small brush a with a watery raw umber and color them before starting with the pastels.I will post a pic of the finished floor later.
 dolly15
Posted: Wednesday, November 15, 2006 - 04:45 AM UTC
dolly15
Posted: Wednesday, November 15, 2006 - 05:36 AM UTC
the above is after one thin wash of raw umber followed by the toothbrush flicking treatment.Pastels will be applied when I figure out where to put the human wear and tear.
dolly15
Posted: Thursday, November 16, 2006 - 08:10 PM UTC
dolly15
Posted: Thursday, November 16, 2006 - 08:50 PM UTC
Engine shop walls.
On some websites the pics are awfully big,I will attempt to change the settings if I can figure out how.Besides it shows all the mistakes!
Anyway this is a pic of a section of the interior wall of the engine shop.I simply laid cardboard over the foamboard and glued it on.The window trim and battens are 1/4 inch coffee stir stiks.On a rough structure such as a barn or hangar they really are all you need but the quality is somewhat poor as you can see from bent and warped shapes and the inconsistent 1/4 inch widths.
They were treated the same way as the floor with watery nimbus grey(the bottom line of vertical boards are the inside of the outside board and batten wall.)The cardboard insulation has been treated with a spray coat of laquer and allowed to soak in.Do not overspray as you do not want a shiny surface.Nail holes were done the same way as the floor.Weathering is next!
dolly15
Posted: Thursday, November 16, 2006 - 09:09 PM UTC
dolly15
Posted: Thursday, November 16, 2006 - 09:23 PM UTC
This is the exterior of the same wall done in board and batten style.The boards are tongue depressors and the battens are those some 1/4 inch stir stiks.The bottom of the boards and battens are left in an irregular pattern as I want to show a little heavier weathering where they come in close proximity to the ground.Additional weathering will be carried out the usual way except the nail heads will show a little rust.
slodder
entire network: 11,718 Posts
KitMaker Network: 2,584 Posts
Nice walls.  have you ever looked at coffee stir sticks for a 'lumber' source.  The ones from places like Starbucks are nice hardwood that would look really good in your application.
dolly15
Posted: Friday, November 17, 2006 - 12:24 AM UTC
Thanks Scott! in addition to the 1/4 inch sticks ,I also use 2 other sizes of coffee stir stiks as well as the tongue depressors.Hobby wood is just too darn expensive.Cheers! John.
dolly15
Posted: Friday, November 17, 2006 - 05:44 AM UTC
dolly15
Posted: Friday, November 17, 2006 - 06:43 AM UTC
Here I have gone over the battens with plain water to swell the nail holes as I didnt want any more of the grey color.Then I took some very watery raw umber and toothbrush flicked a bit of crud on ,after I had protected the plexiglass with paper.I then used a very small round brush and with the same raw umber emphasized where I thought the crud may build up a little heavier over the years.Try to be subtle and take your time,it will be worth it in the end.Now it is on to the pastels!
dolly15
Posted: Friday, November 17, 2006 - 10:38 PM UTC
dolly15
Posted: Friday, November 17, 2006 - 10:53 PM UTC
The work you see here took about an hour to do .Pastels are fun to work with if you dont overdo it.Use a very soft brush and work the pastels into the wood.Because our wood is not sealed this is very simple to do and quite permanent.
Here I have used only 2 colors so far,black and burnt sienna.The most important thing is to use your imagination and have fun with this.The final work with the pastels will be when I put the walls together and decide on the wear and tear.
dolly15
Posted: Saturday, November 18, 2006 - 04:15 AM UTC
dolly15
Posted: Saturday, November 18, 2006 - 04:34 AM UTC
Here is the outside bottom of the same wallpanel.After doing the pin and pencil routine,I took a small burr on a rotary shaft and roughed up the boards near where they come in close contact with the ground outside.I want to show the ground a little uneven where it runs along the concrete foundation.The boards will also have a fungus/mossy green look at the very bottom.Sounds like fun huh!
dolly15
Posted: Saturday, November 18, 2006 - 08:22 PM UTC
dolly15
Posted: Saturday, November 18, 2006 - 09:25 PM UTC
Here I have begun working a bit with the Raw umber.The top portion of the panel has just the pin and pencil and toothbruck flicking techniques.From the mid portion on down,i have taken a very small round brush and with some watery raw umber filled each individual hole so that it swells level and diffuses a little color around each hole.It is important to let the holes wick up the watery mix.Take advantage of the fact that you are using raw, dry wood ,for example at the bottom touch the the ends of the boards with your watery mix and let the wood wick it up just like it would do in nature.When weathering try as much as possible to follow mother natures routine in the aging process.For example:rust would show later in the process than plain crud,moss and fungus still later.For those who maybe worried about the wood not being sealed, you could I suppose, use a spray fixative over your finished panel.(I am not too worried about this as these dioramas are going to a controlled enviroment.)
I find that these panels can be a lot of fun to do if you treat each one as a little artists canvas of its own.Gather lots of reference material and be creative.Make each one a little different as they can be subject to different weathering and lighting in real life.Also keep in mind ,as in my case,the buildings' modules could have been added at different times in the history of your diorama.Smaller buildings and trim could be painted, while large outdoor wallpanels could be left subject to more weathering.Also there could be a cost factor invovled in not completely painting the large main structure.
This is the great thing about diorama making, the learning just goes on and on and there is no time to get bored.It incorporates just about every aspect of modeling and a lot what is called "ART" too.Hope your havin' as much fun as I am.
Cheers! John.
__________________
It has been said that the difference between a "pilot" and an "aviator" is that a pilot is a technician,and an aviator is an artist in love with flight.
JohnReid (Aviator)
Cheers! John.
__________________
JohnReid (Aviator)
slodder
Posted: Saturday, November 18, 2006 - 11:13 PM UTC
Nice update - I like the framing and the technique of soaking the wood to stop the nail holes from being to over powering.
note: check out the time stamps on your post about stir sticks and mine about Starbucks
dolly15
Posted: Sunday, November 19, 2006 - 02:33 AM UTC
dolly15
Posted: Sunday, November 19, 2006 - 02:53 AM UTC
this is about as far as I am going to take it for now.Any additional weathering will be done after I put it together.
Here i have taken a little watery burnt sienna and added a little rust to some of the nailheads.Be careful not to overdo it.I then took a touch of burnt sienna pastel and softened the look a bit.You can continue to shade some of the boards with grey or black or even add some brown if your boards look too grey.I took some very light green pastel and dusted up the windows a bit.I also added a little darker green at the very bottom of the boards to represent a little moss, I am not yet totally happy with the moss color but it gives you an idea about what I am talking about.
In the next pic you can see some of the tools that I have been using.
dolly15
Posted: Sunday, November 19, 2006 - 03:20 AM UTC
dolly15
Posted: Sunday, November 19, 2006 - 09:30 PM UTC
Office module
dolly15
Posted: Sunday, November 19, 2006 - 09:48 PM UTC
This is an old pic of the unfinished office module.I posted it so that you could see how a more painted type finish could be weathered.The weathering is not yet completed but will be much more subtle than the engine shop out back.I figure that is they were going to go to the expense of completely painting any of the structures it would probably be this office.The exterior is an off-white put on in thin washes.Nailheads could in this case be covered with paint except maybe at the very bottom and a few more only lightly rusted here and there to add a little interest.
dolly15
Posted: Tuesday, November 21, 2006 - 10:10 PM UTC
Help!
I am now finishing up the engine room wall panels and about to start on the furniture.If anyone has any pics of a room such as this please advise.
In my imagination I can see lots of parts and pieces laying around and storage space for various nuts and bolts.This shop is designed for light maintenance and not major overhauls.There already is a lathe in the carpenters shop but maybe a nice drill press would be in order.Got any pictures?
__________________
JohnReid (Aviator)
__________________
JohnReid (Aviator)
