Hey .......good start --now box under for running gear ----was going to give a heads up on short cuts --but your ok--
I cut my sides from "point"of nose to back withthe double angle ---if you do the under box and fix you can cut the "whole back " T " piece !! Tip !!----dividers --open to size you require --score the "sheet"(10"x8"??) along the long side --should be enough to give 2 pieces for sides --also gives bottom of "T"" off cuts for cross braces--I would measure the "axle" points and put small drill hole to mark for later I know they are different on each side --staggered --but not much to be noticed
You're on track ---will try to get te picks of bits to you soon
aye
BARV
(GOSMG)
