1⁄35Making Miniature Fake Chains and Springs
Making a fake spring
Finding this technique did involve a bit a lateral thinking. It stemmed from a question from Holdfast, asking if I knew of a way to make a working spring for a 1/48 scale aircraft aerial. Well, I failed on that one but, in the course of experimenting one Sunday morning, found this neat trick to create tiny dummy springs.I started by with the obvious route of wrapping wire or stretched sprue around a drill bit; the results were OK, but still much bigger than I wanted... how to make something even smaller?
Here's what I came up with:
1. Take some fine fuse-wire (5 amp) and clamp it either end (I used a "Helping Hand").
2. Wrap a second piece around it as tightly as possible.
3. Slip the first piece of wire out, and cut the resulting "spring" to length.
Using this technique, the size of the "spring" is only limited by the guage of the wire you use.
Copyright ©2021 by Rowan Baylis. Images and/or videos also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of KitMaker Network, KitMaker Network, or Silver Star Enterrpises. All rights reserved. Originally published on: 2005-08-25 00:00:00. Unique Reads: 41305
