1⁄35Pouring Resin - Without Air Bubbles
5
Jan... good article. As a fellow "Cast-a-holic", i find that in addition to painting a thin layer of Silicon onto the object when creating the mold, it also helps to place the wet RTV and the container on top of your clothes dryer. Throw in a tennis shoe or several towels, and let them spin for about 10 minutes. The vibration of the thumping dryer helps dislodge even the smallest bubbles, delivering a super-clean mold to start with.
Before pouring the resin into the new mold, I first pour in a thin batch of plaster of paris...this is much cheaper than resin for testing purposes, and will serve the same purpose to help you find where air pockets develop.
NOV 05, 2003 - 07:32 PM
ZerO-CoOl suggested to place a drill on the tabletop to create such vibrations. i now use the compressor (airbrush) on the tabletop. That vibrates the air bubbles straght out. Of course, this only works if you have these "evacuation canals" installed to let the bubbles escape.
NOV 06, 2003 - 01:22 AM
good tech tips. Slight correction - don't use a vaccum to get resin bubbles out, as you decrease the air pressure, that will actually allow the bubble to get bigger! A pressure pot gives great results for the resin pouring stage of casting - the incresed air pressure shrinks the bubbles down to mere pin pricks.
NOV 07, 2003 - 06:21 AM
Vacuum doesn't only make the bubble bigger : it s u c k s the bubble out of the resin.
This is still the most used technique by professional resin casters.
Pressure pot works well, too.
NOV 08, 2003 - 12:47 AM
Copyright ©2021 by Jan. Images and/or videos also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of KitMaker Network, KitMaker Network, or Silver Star Enterrpises. All rights reserved. Originally published on: 2003-11-05 00:00:00. Unique Reads: 36849
