Slate sheeting, 0.8 mm thick
Item: 56102
Size: 7 14/16 in. x 4 5/16 in. (20 x 11 cm)
Laser-Cut Textured Building Sheets
NOCH currently catalogs 25 sheets in the following scales:
1/48 - O scale
HO scale - 1/87
TT scale - 1/120
N scale - 1/160
The subjects are wood and slate shingles, cobblestones, brick work, stucco (ashlar) walls, tar paper and tile roofings.
While
Slate sheeting, 0,8 mm thick, 20 x 11 cm is advertised for HO scale - 1/87, it can easily be applied models ranging from 1/72 to 1/100.
In HO the 7 14/16 in. x 4 5/16 in. sheet will roof residential and small industry sized buildings, while two sheets will roof most lineside sized structures.
This sheet has impressive realistic slate shingles.
Please remember to tell manufacturers and retailers that you saw these here - on KitMaker Network!
