MICRO MARK [ MORE REVIEWS ] [ WEBSITE ] [ NEW STORIES ]
Desprung Tweezer
by: Delbert [ DELBERT ]
Sale's Blurb
"Tweezer-Like Nipper Desprues the Tiniest Parts. A gentle squeeze is all that's required to safely separate even the tiniest molded part from its sprue. Finely-ground double-honed tips reach into the tightest locations and flush cut the plastic so that further clean-up is not required. Custom made for Micro-Mark of the highest-quality satin finish stainless steel. For use on plastic sprues only."
The Pro's.
First off calling these tweezers is deceptive as they are made of a much thicker stainless steel and have more heft to them and they feel like they will last a while.
Second the cutting head is perfectly shaped for the job of cutting parts off of the sprue's. The pointed edge of the cutting area is fairly thin and can be slid into the sprue's quite well while at the same time not obstructing your view of the part being cut.
Third, these allow you to cut off very small parts off of sprue's while holding them with a pair of tweezers or your thumb over them to avoid having small parts go airborn on you.
The Con's
First the company claims that further clean up is not needed... I disagree, although they do cut very small parts off of the sprue's cleaner than my regular cutters, there is still a little sanding needed to smooth out the parts.
Second is the fact that unlike plier type cutters that cut by squeezing, with these you are using your fingers to press the sides together to do the cutting. Because of this these are only good for fairly small parts.. the larger the connection of the part to the sprue the more strengh is needed to make the cutter cut..
Conclusions
Overall I like this tool and will find it to be a usefull additon to my equipment for use with detaching those pesky small parts.... But if you expect this tool to desprue everything then you will find it a disappointing buy.
I recently recieved one of these from Micro-Mark and although it didn't live up to all the claims the company made I am still happy with it.
Percentage Rating
70%
  Scale: Other
  Mfg. ID: 82393
  Suggested Retail: 14.95
  Related Link: micromark web catalog listing
  PUBLISHED: Dec 27, 2004
  THIS REVIEWER: 75.00%
  MAKER/PUBLISHER: 81.00%
About Delbert (Delbert)
I'm 51. I've been model building since Dec 2001 and I build everything from wingy things to ground hugger's. esp WWII era. also built a car or two. Some people think my stuff isn't too bad.
Copyright ©2021 text by Delbert [ DELBERT ]. All rights reserved.
  • 82393
