PAASCHE [ MORE REVIEWS ] [ WEBSITE ] [ NEW STORIES ]
Spray Booth
by: Dave O'Meara [ GRUMPYOLDMAN ]
where to start
Well this is probably one of the more difficult reviews I’ve been asked to do. I’ve been trying to figure out what to write about something as mundane as a large tin box that takes up a lot of room, isn’t pretty, may help save your lungs and life, and keep it interesting. I certainly didn’t feel like making it sound like another boring tech sheet.
purchase
After working for more years than I care to remember with the usual window fan on exhaust, I happened to come across a post here on Armorama.com from a fellow member. He was selling an almost new airbrush spray booth, for a really low price. After shooting off a PM, it was mine. After I sent the check for the agreed upon sum, he shipped it to me. The huge box arrived a few days later. Now my usual UPS driver is used to me receiving various size packages, but when this one arrived, he asked if I was now accepting bodies.
consider size
When I opened the package I found a huge, unassembled assortment of sheet metal, a separate fan assembly and a note stating the previous owner only used it once. I quickly assembled it on the floor in the living room. I suddenly realized that I had no place for something this large in my workshop, which is actually the corner of the bedroom. I also had nothing to place it on, so off to do a little shopping.
I went out and bought a three-draw metal file cabinet at the local Staples office supply store, as I could always use the draws for extra storage. I knew I would have to be able to shuffle this huge spray booth around to store and use it. As Grumpy’s luck runs, of course they had no dollies for under the cabinet. So over to the Home Depot I went and they had none either so I ended up buying a small furniture dolly (which turned out fine, since its larger wheels make it easier to roll, and slightly larger size makes it more stable) Back to the apartment to get it set up.
location and setup
After I assembled the spray booth again, I placed it on top of the wheeled file cabinet, and plugged it in. Now on my initial start up I had minimal noise or vibration, but now had a lot. Being sheet metal, the bottom needs to be firmly supported, so back to the Home Depot for a 24x24 piece of 3/4inch plywood. I slipped this under the base and 95% of the noise and vibrations stopped. I then removed the fan plenum and sealed it, along with the sheet metal side panels with some silicone caulking. Now it ran quite and vibration free. Now I just needed to vent it. This is simply a dryer venting kit, which was kindly provided by another member, who even delivered it. Having no on/off switch, it requires you to plug it in to use, and unplug it when done. This can prove to be a pain in a certain area, so I installed a plug strip with an on/off switch, and now have a place to plug in the clamp on lights to see in the spray booth - you’ll need them too!
functionality
Now what about this tin box and how does it work. Well it works great, runs quite, and since I spray a lot of lacquers and lacquer thinned enamels, it gets rid of the fumes out the window without smelling up the house, and killing my lungs and brains any more than they already are.
Providing an air extraction between 80 to 100 LFM (Linear Feet per Minute), it does warn you if you are spraying harmful solvents it needs to be vented to the outside, so be warned. The fan motor is mounted outside of the airflow, and poses no sparking danger. Measuring a large 24 inches by 24 inches work surface, and 18 inches high, it will take up a lot of room. Weighing 42 pounds, it’s not something you will want to put up and take down, unless you like excessive work and self-torture. Listing at $288.99 plus shipping at http://www.dickblick.com it’s not exactly cheap, but then again what are you and your families’ lungs worth?
It uses a carbon and fiberglass filter to removes the larger particles from the exhausted air. I usually pick these up at the Home Depot, and simply cut them to fit.
For the average modeler and those doing smaller projects it is surely over kill, as there are smaller and much more portable spray booths available. For those that spray larger objects, and need something this size I would surely recommend it.
I also use it for my photo booth, for this I simply use some precut illustration board. I glued some magnetic strips on the back, and stick and slip them in place when I need to take photos.
Air brushes are wonderful tools. Their effectiveness can be reduced if a proper area is not used. Here is a premade Spray Booth designed just for airbrushing that will help you get the most out of your air brush and create a wonderful finish on your models.
  VENTING POWER:90%
  PORTABILITY:50%
Percentage Rating
90%
  Scale: Other
  Mfg. ID: Model 24-18
  Suggested Retail: $400.00 list
  PUBLISHED: Aug 11, 2006
  NATIONALITY: United States
  THIS REVIEWER: 87.92%
  MAKER/PUBLISHER: 88.33%
  • Doubles_asPhotobooth4
  • Doubles_as_Photobooth3
About Dave O'Meara (Grumpyoldman)
I'm rewriting this in a much more humoristic way, to help over inflate my ego, and place my self on a pedestal, because I don't have a life, and plastic models are the only thing I live for. I plead guilty as charged to excessive babble, light hearted humor, and continued encouragement to youngsters...
Copyright ©2021 text by Dave O'Meara [ GRUMPYOLDMAN ]. All rights reserved.
Nice editing Scott, you made me sound so intelligent... :-) Forgot to mention, if you have a SWMBO, I sure she would not like this set up in the corner of the bedroom. :-)
AUG 10, 2006 - 08:13 PM
Dave - I think if you painted it a color complementary to the drapes you'd be fine #:-)
AUG 10, 2006 - 08:39 PM
Nice article dave... il be considering making one now. Frank
AUG 11, 2006 - 02:50 AM
Thanks for a great article. I would like to copy your design for a booth in my studio if I may. I was not really sure how to go about the extractor fan and filter and you how to explains it so even an old coot like me can understand it. Thanks again Grumpy. animal
AUG 11, 2006 - 03:48 AM
Not my design, it's paasche's.... But I'm sure anyone with a little tin knocking experience could bang one out, sizing it to suit their needs. Could also be made by someone with a little skill using plywood.
AUG 11, 2006 - 04:55 AM
Great review, Dave, very well written, mate! As you have just said, these are not hard to make if you have a little sheetmetal knowledge...a few years back when I still worked in a shop, in slow times my shop steward and I used to bang out quite a few of these for our buddies. Total cost in materials (minus the fan) was about 6 bucks in metal and screws...and any exhaust fan can be adapted to suit. I like your set-up, and the photo-studio idea is a banger! Thanks! Keep Modeling! ~Gunny
AUG 11, 2006 - 05:31 PM
  • CompanyPhoto
  • Hughsize
  • Stowed-NOT_really_Apartment_size
  • Rearview
  • RearView2
  • Regular_Airfilter
  • Venting_to_outside
