Arkansas, United States
entire network: 11,610 Posts
KitMaker Network: 3,657 Posts
Posted: Tuesday, September 29, 2015 - 10:08 AM UTC
You can use the CD as a straight edge
And I thought CD's were round?
Ideals are peaceful. History is violent.
Joel_W
Associate EditorNew York, United States
entire network: 11,666 Posts
KitMaker Network: 121 Posts
Posted: Tuesday, September 29, 2015 - 08:02 PM UTC
For PE cutting PE I use a small curved Exacto blade not the larger #10 blade, and I roll it back and forth over the tab a few times to cut off the part. I make those cuts on a flat ceramic tile from a Big Box Hardware store. They cost way less then a dollar each. The key to cutting PE is the cutting surface. It has to be flat with no give, otherwise the PE attachment point just creases into the cut surface.
For larger,thicker PE parts I use a small pair of nail cutters. Just make sure that you hold on to the part, or you'll be visiting the carpet monster.
Joel
On my Workbench:
Monogram 1/24 scale 427 Shelby Cobra
Just Completed:
Beemax 1/24 scale BMW M3 E30 1992 Evolution II
Connecticut, United States
entire network: 3,608 Posts
KitMaker Network: 512 Posts
Posted: Tuesday, September 29, 2015 - 08:07 PM UTC
I cut on the CD. It's hard enough to prevent bending the part, but pliable enough that it absorbs the force of the blade. It doesn't launch parts like glass does. I always keep my finger over the part to be safe.
Best,
Matt
SSG, INF, USA (Ret.)
"I am waiting for the tanks, and the Americans."
General Philippe Petain, September 1917
entire network: 100 Posts
KitMaker Network: 24 Posts
Posted: Tuesday, September 29, 2015 - 08:17 PM UTC
thanks! Now I need to find a pair of damn cutters that fit in between the part and the sprue, or try other blades liek the curved one mentioned earlier. The Xuron cutter blades are too fat. Perhaps it is just the Voyager brand PE that has less space than other brands. dunno..
SgtRam
Contributing Writer
#197
entire network: 3,971 Posts
KitMaker Network: 568 Posts
Posted: Tuesday, September 29, 2015 - 08:38 PM UTC
I use a small hard bamboo cutting board to cut PE on. I find it hard enough to prevent most pieces from deforming, expect for the microscopic parts, and does little or no damage to the blade.
