Scratch Build Stone Walls
3
Easy Stone Walls
Pre-mixed drywall paste, craft type acrylic paint and a mold made from a cat litter pail lid can make anyone an expert "Stone Mason" in any scale.Step 1
Mix water based acrylic paint with the drywall paste.Step 2
Spread it out evenly onto your "casting surface" (Mold). Here I have used the lid from a pail of cat litter as my mold. This is where you determine the thickness of your stone. I wanted flat, semi-thin rocks, so I went about 2 -3 mm's thick on the spread. Let dry for at least 12 hours.Step 3
Once dry, it can be broken into whatever size stone you require (this is why this process works so well in any scale).Step 4
I used a piece of scrap sheet styrene as a base to ease assembly and facilitate any detail painting, drybrushing, etc.. I used Crazy Glue (CA) in assembly but I'm sure that you're favorite brand will do as well.Step 5
The assembly was attached to the base upon its completion.Editors Wrap-up
That covers the basic technique. You should seal it and finish it with standard techniques. Dave shows his materials and finishing techniques.Comments
Great tips. As I keep forgetting to grab some litter, I will have to make a note and pick some up so I can try this.
Ironmike
JUL 01, 2008 - 04:04 AM
Looks great, Dave. Would fir very well with a lot of different middle East and Southern Europe dioramas.
Thanks for sharing
JUL 10, 2008 - 07:35 PM
Hey Razorboy,
That's a pretty slick method for making a stone wall. I was kinda kickin around doing a Normandy '44 dio and was curious about the extensive use of stone masonry in the villages and how to go about replicating it. Eureka! I think I found what I was looking for in your article. Thanks for getting me "stoned".
Best Regards,
AUG 01, 2008 - 08:46 PM
Copyright ©2021 by Dave Creel. Images and/or videos also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of KitMaker Network, KitMaker Network, or Silver Star Enterrpises. All rights reserved. Originally published on: 2008-06-22 00:00:00. Unique Reads: 42571
